LMS 3.2 - Exporting/saving HUM poller/threshold configuration
May 18th, 2010
Hi there,
due to a db-crash we had to reinit our HUM-DB.
Unfortunately every HUM-configuration (poller/thresholds/reports) seem to be configured
in the HUM-DB.
So we have to build the config from scratch.
It is only possible to export templates.
Are there any (hidden) CLIs for extracting and restoring these HUM-Configurations?
Thanks for any idea.
Lothar
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 05/18/2010 - 09:48
Unfortunately, there are no tricks to get this data back in.  It will all have to be done manually (including reloading any custom MIBs).
lo.mueller Tue, 05/18/2010 - 22:38
Hi Joe,
thanks for the update.
Are there any plans to implement an export-script / procedure for future?
This would be very helpful.
Couldn't this be done with "some" SQL-Statements(???)
Thanks for any update
Lothar
Joe Clarke Wed, 05/19/2010 - 08:52
There are a lot of table interdependencies in HUM, so trying to manually hammer in previous templates would not work.  LMS 4.0 does not offer any new CLI capabilities for performance management (HUM as an application no longer exists), and I have not heard of any plans to create any.
