05-18-2010 01:17 AM - edited 03-04-2019 08:31 AM
Dear All,
Please let me know Routing throughput of cisco 3750 and 4500 series cisco switches.
Cisco WS-C3750-48PS-E
Thanks in anticipation.
Dipak...
05-18-2010 01:20 AM
Switch performance is 38,700,000 mpps and 32Gbs switch fabric. What is the supervisor engine of the 4500?
05-18-2010 02:26 AM
Thanks for the Quick response.
I need the routing throughput...
Dipak
05-18-2010 04:58 AM
Hi Dipak,
Leo has actually answered your question until unless your unerstanding of routing throughput is different.
Routing is nothing but get to know the interface from where next hop of destination can be reachable. Once information is obtained, switching process starts to send the packet to next hop.
Cisco Layer 3 switches use CEF to fasten the process of routing.Taking routing topology & underlying routing/switching mechanism to be same (CEF), bottom line is how fast a hardware can process a frame (i.e. MPPS) and how fast it switches the traffic between port via backplane (gbps switch fabric)
Leo has mentioned the 3750 throughput and depending on SUP engine, 4500 throughput will vary.
3750 datasheet
4500 datasheet
** In case of 6500, type of line card & DFC add on are the additional factors while computing throughput.
Hope to help
Kind Regards,
