Can I use IP phones if I terminate analogue on a VG224
Answered Question
May 18th, 2010
Hello all
Can I use IP phones once I have terminated analogue lines into a VG224 from my UC500 paltform?
Correct Answer by James Hawkins about 6 years 9 months ago
The VG224 provides 24 FXS ports which can be used to connect analog phones, fax machines etc. It cannot be used to connect external analogue lines.
You need a device with FXO ports for that purpose. You can fit up to 8 FXO ports into a UC520. If you need more trunks then it makes sense to look at an T1/E1 link or optionally SIP trunking.
Overall Rating: 5 (1 ratings)
Correct Answer
James Hawkins Tue, 05/18/2010 - 03:21
simonmossman Fri, 09/24/2010 - 01:59
Hi James
I know this a bit late but thanks for the response....as you were correct in what you said. I will score this as answered.
