Devices Configs. Backup from CSM
May 18th, 2010
How to schedule a backup job for the configuration files of the devices added in the CSM (Cisco Security Manager) Version.3.3.
Jennifer Halim Tue, 05/18/2010 - 04:05
To perform backup:
Tools --> Backup ... --> it will then open another browser where you can configure immediate backup, daily/weekly/monthly backup.
Hope that answers your question.
Panos Kampanakis Tue, 05/18/2010 - 07:13
Halijen provided a way to do a backup of CSM DB using the CSM client.
If you want to schedule backups of configs of devices in CSM, CSM cannot do it on its own. It does keep an archive of the c
onfig files whenever it deploys to a device. But if you want to get a config file every night you need Cisco RME (Resource Manager Essentials) that is integrated with CSM and manages configurationgs and software versions. Here is the product overview
I hope it helps.
