CUCM 6.1.5- IPMA Problem
May 18th, 2010
Hi all,
I have a IPMA configured in my call manager, version CUCM 6.1.5-10000-10
When I do any change in the IPMA service or restart the service, I can't login with the Assistance User without first to have save the configuration of Manager.
The Assistamce User is:  IT000276
The Manager User is: IT000255
I attached the logs of IPMA.
I you need more information you can request me.
Thanks for all.
ma.romero Thu, 05/20/2010 - 08:04
Sorry the logs are wrong. Here I attached the correct logs.
But when I do login the error which appear is: "System Error. Please contact your  administrator" or in spanish: Error de Sistema. póngase en contacto con el Administardor.
The problem occur about 3/5/2010 between 22:00 and 23:00. Appear the error about 22:52.20: "ERROR!! Cannot find key: rtlFlag in resource bundle: Dialog". The Assistant is IT000276 and the manager is IT000255.
Too, 12/5/2010 between 22:30 and 23:30 I have the same problem and appear other.
When the IPMA service is restarted I can't login with the Assistant. First I have to login with the Manager (user IT000255) and after login with the Assistant. is it normal?
Thanks for all.
LUIGI PIETRONAVE Sun, 08/22/2010 - 13:56
did You solved this behaviour ? I've the same, also if the callmanager is 7.1
Many thanks
ma.romero Mon, 08/23/2010 - 00:23
I forward the problem to my other partners and I don't know if this issue was resolved.
The version of call manager ir CUCM 6.1.
A greeting.
