Panos Kampanakis Tue, 05/18/2010 - 10:01
You can do "debug h323" to see why the h323 packets are dropped if they are dropped by inspection.
I hope it helps.
PK
Diego Armando C... Tue, 05/18/2010 - 10:23
Could you also do a show service-policy
to see if the inspection is really dropping this packets.
searskarthik Wed, 05/19/2010 - 04:52
Yes, I have done both the options. 8.04 its working with out any issue.
But i wnat to run in 8.3.1 version.
thanks
Karthik
Panos Kampanakis Wed, 05/19/2010 - 05:57
It could be a translation issue as you migrate from 8.0 to 8.3.
I suggest a TAC case for them to investigate deeper.
PK
searskarthik Thu, 05/20/2010 - 00:18
yes, anway again i going to test with 8.3 code with
another ASA . i will update the result.
thanks
karthik
