CUCM Upgrade from
May 18th, 2010
Hi everybody,
I am facing an upgrade from CUCM 5.1 with the System Version to 7.1(5)
I can't find this particular release in the compatibility matrix:
so I am a little bit afraid, cause it might be an engineering special or something like this.
I can't find anything after 5.1(2b), which is
I think I have to go through 5.1(3f), which is the "newest" version supporting upgrades from 5.1.2 and then go directly to 7.1(5).
Any hints are welcome.
Kind regards
rob.huffman Tue, 05/18/2010 - 06:36
Hi Christian,
The version you are running is in fact an ES (engineering special) as you nicely
noted You should be fine to move forward with your suggested upgrade path.
From the doc you linked;
Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades
If you run a Linux or Windows Engineering Special (ES), a Service Update (SU), or a Windows Service Release (SR) for any version listed in the "Direct upgrade" tables in the following Supported Cisco Unified Communications Manager Upgrades, you can also upgrade to the target version for that section.
Please support CSC Helps Haiti
