DAVID ANDERSON Tue, 05/18/2010 - 06:10
Federico,
Many thanks for your rapid response. I will have a read up on that now on how I get that implimented instead.
Jennifer Halim Tue, 05/18/2010 - 06:06
You can configure IPSec VPN Client instead. It achieves the same where you connect to the PIX remotely via VPN to securely access resources behind the PIX firewall.
Here is a sample configuration for your reference:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
You would need to install the Cisco IPSec VPN Client on the user PC.
Hope that helps.
Federico Coto F... Tue, 05/18/2010 - 06:10
David,
halijenn is correct.
However IPsec VPN client requires the installation of a software client (if you can do it, this is the recommended client).
As with PPTP, you can configure L2TP using the native windows VPN client without any additional software.
Federico.
DAVID ANDERSON Tue, 05/18/2010 - 06:20
Hi halijenn,
Thanks also for your rapid response. The link will be a great help and will use it to setup remote access.
Thanks Dave.
