ACS 5.1 appliance and 3750 Switch
May 18th, 2010
I'm trying to add a 3750 to our new ACS 5.1 appliance for tacacs authorization
Attached is the config I have on the 3750 and a debug.  After I enter this information the enable command and all futher commands say "Command authorization failed."
My ACS has this specific device added to the "Network Devices and AAA clients" area of ACS with a Tacacs shared secret PW the same as my Key on the 3750.
Javier Henderson Tue, 05/18/2010 - 10:04
  • Cisco Employee,
What is ACS reporting as the reason to fail the authorization?
Joseph Dworak Tue, 05/18/2010 - 11:01
ACS report and monitor shows my account :
Status:
Passed
Failure Reason:
Logged At:
May 18, 2010 12:58 PM
ACS Time:
ACS Instance:
NAWDM1ACS-A01-DC03
Authentication Method:
PAP_ASCII
Authentication Type:
ASCII
Privilege Level:
User
Username:
abc123
When I type enable or any other command it says:
Chetan Kumar Ress Tue, 05/18/2010 - 12:01
  • Silver, 250 points or more
As you mention you are able to login but You are not able to get authorized for enable & config .
Did you setup ACS for authorization ?
Please let us know the so can come with solution
Javier Henderson Tue, 05/18/2010 - 12:09
  • Cisco Employee,
That is the authentication report. Please look in the authorization report.
Chetan Kumar Ress Tue, 05/18/2010 - 12:20
I recommend you to modify the AAA command to Support Authorization & In ACS configure user privilege to 15 &
Give authorization of config terminal
aaa authentication login default group TACACS
aaa authentication enable default group TACACS
aaa authorization exec default group TACACS
aaa authorization config-commands
aaa authorization commands 0 default group TACACS
aaa authorization commands 1 default group TACACS
aaa authorization commands 5 default group TACACS
aaa authorization commands 15 default group TACACS
aaa accounting default group TACACS
Joseph Dworak Tue, 05/18/2010 - 12:50
I'm getting closer:  THANK YOU FOR ALL YOUR HELP SO FAR!!!!  I'm sending this but also looking into the failure reason.  I'm a n00b at this version . . . working to get off a Win Radius . . .
Here is the latest authorization report:
Status:
Failed
Failure Reason:
13025 Command failed to match a Permit rule
Logged At:
May 18, 2010 2:42 PM
ACS Time:
ACS Instance:
NAWDM1ACS-A01-DC03
None
Header Privilege Level:
Command Set:
[ CmdAV=enable  ]
User
User Name:
abc123
Remote Address:
Network Device
Network Device Name:
TestPrintroom3750
Netwok Device Group:
Device Type:All Device Types:Switches:West, Location:All Locations
Device IP Address:
10.32.128.9
Access Policy
Access Service:
Default Device Admin
Identity Store:
Selected Shell Profile:
Matched Command Set:
Selected Command Set:
DenyAllCommands
Active Directory Domain:
Identity Group:
All Groups:Administrators:NetEng
Access Service Selection Matched Rule:
Rule-2
Identity Policy Matched Rule:
Default
Selected Identity Stores:
Query Identity Stores:
Selected Query Identity Store:
Group Mapping Policy Matched Rule:
Authorization Policy Matched Rule:
NetEng
Authorization Exception Policy Matched Rule:
Other
ACS Session ID:
NAWDM1ACS-A01-DC03/63492254/359
Author Reply Status:
Other Attributes:
ACSVersion=acs-5.1.0.44-B.2347
ConfigVersionId=38
Device Port=22378
Protocol=Tacacs
Type=Authorization
Service=None
Port=tty1
Remote-Address=10.32.128.26
Service-Argument=shell
AuthenticationIdentityStore=Internal Users
AuthenticationMethod=Lookup
SelectedAuthenticationIdentityStores=Internal Users
UserIdentityGroup=IdentityGroup:All Groups:Administrators:NetEng
Chetan Kumar Ress Wed, 05/19/2010 - 05:02
Dear Joseph
Configuring AAA  with ACS is not so complicated.
Please follow the below steps :
1] Create Loopback Add in router for Management & Communication with ACS Server.
2] Add loopback address in ACS server with Pre-Shared Key with TACACS+ protocol & check mark frist option. ( As below you can see some option that you need to select or check mark)
3] If you are using loopback address then user ip tacacs source interface looback(number)
4] Configure AAA In router but after adding the loopback Ip address in ACS that you had configured in router for management.
5] Create a group in ACS for different privilege access & in that group you can see authorization section , were you need to give authorization with initial   command.
For Example : Create an group and give privilege access of level 15 & in authorization section give command conf t and add in permit list.
And as you shared tha AAA command , I Personaly not recommend to use that one becasue it will not work when your ACS server will fail.
With TACACS group add local also , So if ACS will fail then you can login with local user.
Chetan kumar
