IOS content filtering on SR-520
May 18th, 2010
Hi, I hope you can help me with this, I have a Cisco SR-520 router which I am trying to configure and install the IOS content filter. I have read many of the documents on this but some of the lines do not work, from using the pages below
https://supportforums.cisco.com/docs/DOC-8028
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6643/white_paper_c89-492776.html
you are supposed to enter parameter maps as follows:-
parameter-map type trend-global global-param-map
server trps.trendmicro.com
cache-size maximum-memory 256
cache-entry-lifetime 1
these entries just do not work on the SR-520, you recieve this
#parameter-map type trend-global global-param-map
% Invalid input detected at '^' marker.
Also you receive the following when attempting to check the subscription status:-
router#show ip trm subscription status
The router has 12.4 (20) T4, which is supposed to be supported, the only other way of configuring is using CCP which is not compatible with SR-520's you recieve hardware not supported message's.
Any help greatfully appreciated, or if anyone has acutally got this to work i would love to see the config section!!!!
Dave
Panos Kampanakis Tue, 05/18/2010 - 09:55
  • Cisco Employee,
Can you check your image? Is it Advanced IP Services or Advanced Security?
PK
davestar5 Wed, 05/19/2010 - 04:27
The System image file is "flash:sr520-advipservicesk9-mz.124-20.T4.bin"
Many thanks
Dave
jubetz Fri, 07/22/2011 - 18:20
  • Cisco Employee,
You need 12.4(24)T or later for that platform. Upgrade and you'll be g2g.
Thank you for clarification.
These are three SR-520 routers with IOS Content Filter Subscriptions that were donated by Cisco to a non-profit organisation via TechSoup Canada ... hence no service contract.
Should there be another way of getting upgraded firmware, please bring it to my attention.
Thank you again, Albin.
