Will a 3945 used as a Voice GW pass ISDN PN to SIP as well as CLI
May 18th, 2010
I am using a 3945 to take a PRI 2M input from a auto dialler, I am then converting this to SIP to pass to a VoIP switch which is doing the PSTN breakout.  I need to set a network CLI as one number, however also pass a presentation number which will be different.  If the dialler sends both numbers (or just a PN and I set the network cli on the GW) will the GW pass it by default or do I need to add some config?  Will a PN be passed into SIP at all?
Related Content
