QOS Bandwidth
May 18th, 2010
How does QOS bandwidth work?
Example
If traffic going from my CE to PE requires 5mg of EF1 and traffic from my PE to CE also requires 5mg of EF1 does this mean I need 10mg of bandwidth or are the two queues separate?
Dave
Jon Marshall Tue, 05/18/2010 - 13:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Example
Dave
Dave
No you need 5Mbps of bandwidth at either end.
Jon
DaveSpratt Tue, 05/18/2010 - 14:09
Thank you very much for replying Jon most appreciated.
Therefore when ordering QOS bandwidth from my provider I only have to take into account my traffic leaving and do not have to worry about adding the incoming traffic?
Dave
Jon Marshall Tue, 05/18/2010 - 14:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dave
Dave
Basically yes. If you need 5Mbps of bandwidth across their network you order 5Mbps ie. you do not need to double up the figures.
Jon
Edison Ortiz Tue, 05/18/2010 - 14:25
  • Hall of Fame,
    Founding Member
Misread the original post. Disregard..
Message was edited by: Edison Ortiz
Mohamed Sobair Wed, 05/19/2010 - 00:42
  • Gold, 750 points or more
You dont need 10 Mbps , you will need 5 Mbps , your  router contains two hardware queues , Input and output that can hold 5 Mbps each.
Mohamed
