Question about ASR 1002 and SFP-GE-T modules
Answered Question
May 18th, 2010
Hi all I have asked two ASR 1002, but the true is that I never used / touch this boxes.
The idea is connect this two routers trough Metroethernet link but I am not sure if this interfaces with this Gbic modules  SFP-GE-T works 10/100/1000 or only works at 1000 like 4924 multilayer switches.
My current Metroethernet Link is just 10/100 FE
Somebody knows about that?
Thanks in advanced
Correct Answer by Reza Sharifi about 7 years 2 months ago
Hi Eduardo,
If it is 10/100/1000 then that is what it is.  it is not 10/100  10/100/1000 interface is copper not fiber
Reza
Overall Rating: 5 (1 ratings)
Reza Sharifi Tue, 05/18/2010 - 19:18
  • Cisco Designated VIP,
    2017 LAN
That is Gig only.
Reza
eduardo.ramirez Wed, 05/19/2010 - 13:02
Hi Reza thanks for your response.. .
I heard from other Engineer that 10/100/1000 built-in interfaces are only capable of 10/100 using the copper SFP..
did you know abou that  ?
Correct Answer
Reza Sharifi Wed, 05/19/2010 - 13:17
    2017 LAN
Hi Eduardo,
Reza
chris.rae07 Wed, 05/19/2010 - 23:23
Guys,
I am just deploying a pair of ASR 1006.
I am using the SPA-5X1GE-V2 with both GLC-T and SMF SFPs
cisco ASR1006 (RP1) processor with 709790K/6147K bytes of memory.
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
2097152K bytes of physical memory.
942079K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
This is with Autonegotiation enabled
Router(config-if)#
Router(config)#int g0/0/0
Router(config-if)#speed ?
  10    Force 10 Mbps operation
  100   Force 100 Mbps operation
  1000  Force 1000 Mbps operation
Router(config-if)#speed 100
Auto-negotiation is enabled. Speed cannot be set
Turning off Autonegotiation
Router(config-if)#no negotiation auto
Router(config-if)#speed 1000
Hope this helps
Chris
