CUCM 7.1(5) - Caller ID Not accurate
Answered Question
May 18th, 2010
Greetings,
Have a CUCM 7.1(5) box with 2921 H323 gateways and PRI's to the PSTN.  I have set my external Phone number mask to the standard format AAABBBCCCC.  When I tell the route pattern or route list to use the phones external mask I see the Calling party as AAABBAAABBBCCCC when it is leaving my gateway to the PSTN.  I see the same thing on both gateways and all 4 PRI's.  If I hard set the CallerDN on the gatways in CUCM I get AAABBAAABBBCCC when the call leaves the gateway to the PSTN.  Not even sure where to start looking at this one.
Thanks.
Correct Answer by William Bell about 6 years 11 months ago
Sounds like there is a possibility that you are prefixing digits on the calling party IE at the gateway.  This would be done via translation-rules/translation-profiles on the voice gateway itself.
Look for a translation profile that is using a translation rule for the "calling" party in your IOS config.
You could also check DNA on the CUCM to see if the calling party transform is occurring somewhere else.
HTH.
Bill
Overall Rating: 5 (1 ratings)
Correct Answer
William Bell Tue, 05/18/2010 - 21:58
  • Purple, 4500 points or more
HTH.
Bill
ahochau_2 Wed, 05/19/2010 - 20:15
Yup, someone had "helped" me by adding the translation rules.
Thanks!
