cisco asa 5500 vpn sessions
Answered Question
May 18th, 2010
Hi there
it may sound like a trivial question, but does anybody know what exactly means
"Maximum site-to-site and remote access VPN sessions"
lets take ASA 5505
it is stated, that it supports up to 10 sessions
does it mean that i can interconnect 10 of these devices together over VPN with some count of PC's behind each of them
or maybe it means, that only 10 PC's can communicate over VPN *simultaneously*, even if i have 10 ASA's interconnected together like in previous example
thank you for advice
Andrew
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Thank you for reply
but what is session in the case of site-to-site vpn?
Is this a session between computers connected over vpn,
or may be, this is a session between firewall/vpn devices?
As Rick said session means for site to site between the devices at each location for remote to site pc to vpn concentrator.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Richard Burts about 6 years 9 months ago
For site to site VPN a session is a connection between 2 firewall/VPN devices.
For remote access VPN a session is a PC with VPN session to the ASA.
Rick
Overall Rating: 5 (2 ratings)
Ganesh Hariharan Tue, 05/18/2010 - 23:15
Hi there
lets take ASA 5505
Andrew
Hi Andrew,
As per the link i think 10 concurrent session for site to site with 25 remote to site with security plus license.
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hope to help !!
Ganesh.H
Asthaonard Wed, 05/19/2010 - 05:13
Thank you for reply
Correct Answer
Richard Burts Wed, 05/19/2010 - 12:48
Rick
Correct Answer
Ganesh Hariharan Thu, 05/20/2010 - 01:08
Thank you for reply
Hope to Help !!
Ganesh.H
