Cisco router built-in TCP port number for telnet
May 18th, 2010
Can someone pls explain to me what is the purpose of port numbers 2000, 3000, 4000? For example, I know if I use port 2097 (2000 + 97) using the example below, I can do a reverse telnet with serial3/0 interface. Are the port numbers (2000/3000/4000) user definable? When should I use 2000 or 3000 or 4000? Thank you.
# telnet a.b.c.d 2097
interface Serial3/0
physical-layer async
description Connected to TNT GHU
no ip address
encapsulation slip
line 97
modem InOut
no activation-character
transport preferred telnet
transport input telnet
transport output telnet
stopbits 1
speed 2400
Cisco#sh line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
     0 CTY              -    -      -    -    -      0       0     0/0       -
    97 TTY   2400/2400  - inout     -    -    -     52       3     0/0     Se3/0
pllim Wed, 05/19/2010 - 00:26
I have already searched in Cisco IOS command documentation but can't find anything useful. Still searching...
Giuseppe Larosa Wed, 05/19/2010 - 00:26
Hello Pllim,
line numbering is platform dependent.
for C3600
in C3600 should be from 0 to N with 32 positions for each slot so 97 and line 3/0 are a good match
in older routers it was different and aux number changed depending on router effective installed modules.
for 1800,2800, 3800
you should use 2000+line# for reverse telnet, the other port ranges 3000, 4000 have different use
I couldn't find a link at the moment but this is sure
they may be used for X.25 or LAT protocol translation
Hope to help
pllim Wed, 05/19/2010 - 03:02
I found an example of port 4321 used for Stream TCP (see below). Is the port number range 4000 meant for Stream TCP?
Stream TCP Autocommand Procedure
In the following procedure, a line is configured so that any connection into it is automatically connected using Stream TCP to the application server at the specified IP address and TCP port (IP address and TCP port 4321 in the examples).
pllim Wed, 05/19/2010 - 18:50
I found a previous posting. It answers my question.
Re: Reverse Telnet to Async Ports
Range           Description
2000            normal TELNET (full options negotiations, remote echo)
                see RFC-854, also stuff on TELNET in RFC-1123
3000            normal TELNET to rotary
4000            raw TCP (stream) - no TELNET NVT.  See RFC-793.
5000            raw TCP (stream) to rotary
6000            TELNET binary mode - see RFC-856
7000            TELNET binary mode to rotary
8000            forward Xremote
9000            reverse Xremote
10000           reverse Xremote to rotary
telnet = CR LF
binary = CR NULL          6000
stream = No negotiations     4000
Stream would usually be to a printer; binary would usually be to a host application that is running.
Related Content
