1841 router
May 18th, 2010
we are going to use cisco 1841 router. i want to configure leased line inthis router .i will be connecting the local lan in fast ethernet 0/0 with ip 10.10.10.1 subnet 255.0.0.0 and i will be connecting the leased line in the serial port with ip 94.56.xxx.xxx subnet 255.255.255.252. help me to configure this  router .pls provide me the command to configure this router.
Giuseppe Larosa Wed, 05/19/2010 - 00:09
Hello Viraj,
using a /24 mask is better for LAN:
you need to use NAT to provide internet access
int fas0/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
int ser0/0
ip address 94.56.x.y 255.255.255.252
ip nat outside
access-list 11 permit 10.10.10.0 0.0.0.255
ip nat inside source list 11 interface ser0/0 overload
ip route 0.0.0.0 0.0.0.0 94.56.x.z
! where 94.56.x.z is the next-hop on the wan interface
Hope to help
Giuseppe
