3725-IOS upgrade
Answered Question
May 19th, 2010
hi ,
can anybody give me the steps of 3725 ios upgrade procedure?/thx
Correct Answer by Ganesh Hariharan about 6 years 10 months ago
hi ,
Check out the below link for ios upgarde procedure for cisco routers
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Correct Answer by Jon Marshall about 6 years 10 months ago
WEERAKOO69BA wrote:
hi ,
Pretty straightforward -
1) make sure you have enough memory in flash to store the new image
2) if you don't you will need to delete existing image
3) setup a tftp server with the new IOS
4) on the 3745 - copy tftp flash:  then answer the prompt questions
5) if you only this one new image in flash reload the router
6) if you have more than one image -
   3745(config)# boot system flash flash:/
if there is already a boot system flash command in running config for your existing IOS you need to delete that one, enter the one above and then put the old one back so that they are in the right order as the router loads the first IOS it finds in the boot system statements.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 05/19/2010 - 01:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
WEERAKOO69BA wrote:
hi ,
Jon
Correct Answer
Ganesh Hariharan Wed, 05/19/2010 - 08:59
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
hi ,
Hope to Help !!
Ganesh.H
