why AP1142 802.11N 144M?
May 19th, 2010
why 144M on 1142 802.11N?
1142 configuration
dot11 ssid WPA2
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 03550958525A771B165049
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid WPA2
antenna gain 0
no dfs band block
channel width 40-above
channel 5745
i dont understand AP's speed...
please help..
Peter Nugent Wed, 05/19/2010 - 14:02
I dont understand what you are asking?
Are you only seeing 144Mbps throughput?
shinwoo_acdc77 Wed, 05/19/2010 - 19:03
thanks your reply..
Yes.. under 144M... why not display 300Mbps ?
notebook is ThinkPad X300... good PC...
i dont understand..
Peter Nugent Thu, 05/20/2010 - 02:23
Tere are 32 different MCS (modulation coding schemes) in 802.11n. The data rate shown on your laptop depends on a lot of factors.
Security if you dont use wpa2-aes or open then you only see legacy data rates.
If you have a long guard interval you get 130Mbps
It appears you are only seeing a single channel with short gaurd interval MCS 15.
If you have 40MHz wide bonded channels it may be the client capabilities.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
