fax on fxs port
Answered Question
May 19th, 2010
hi,
i hope someone can assist me please.
i ahve a client with a 2821 SRST router. this router has an E1 for local PSTN breakout and a 2-port FXS module for fax. i installed the fax and configured the dial-peer and voice port last week and it was working fine until friday.
now if i try receive a fax it just rings and is not answered. if i try sending a fax it does not dial. this is now becoming urgent as they have no faxing.
here is the config on the gateway (attached)
thanks
Dimitri
Correct Answer by William Bell about 6 years 11 months ago
So, you started having the issue on Friday and something in your config changed on Thursday:
Current configuration : 4016 bytes
! Last configuration change at 16:59:46 BST Thu Apr 22 2010
! NVRAM config last updated at 16:59:48 BST Thu Apr 22 2010
So, what was it that changed?  I would check there first.
Also, when you say that an ingress fax rings but is not answered, do you mean that the receiving fax machine is ringing or that you just hear the alert tone on the calling station.  Have you checked cables to make sure they are connected to the correct port on the gw and fax machine?  Sounds silly I know but if you are troubleshooting this remotely and haven't had the users make sure someone didn't move the fax machine, you will feel even more silly later.  I would also check a different analog device (doesn't need to be a fax) to ensure that you can place/receive voice calls on that particular port.  Sort of a stretch but the fax machine could be malfunctioning.
So, check the physical layer.  Then check the human layer (i.e. the config change).  Then let us know and folks can offer up suggestions on the VG side.
HTH.
Bill
Overall Rating: 5 (2 ratings)
Correct Answer
William Bell Wed, 05/19/2010 - 04:54
  • Purple, 4500 points or more
HTH.
Bill
dnicolaides Wed, 05/19/2010 - 05:02
Hi Bill,
Thanks for the information. When i spoke to the guys onsite they assured me that no changes had been made on the VG. Strange i know, how else does something just stop working hey?
So if i call the fax number (xxxxxxx8519) i can hear the ringing tone in my ear but the fax machine never answers the call. Ie. I don’t hear the fax tone.
I checked yesterday and the fax cable was plugged into the "line" port on the fax machine and the cable was plugged into port 0 of the FXS module in the router.
I will have someone check with an analog phone shortly and update.
Thanks again,
Dimitri
Rob Huffman Wed, 05/19/2010 - 06:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Bill,
Loved the "Human Layer" reference +5 all day long!
Cheers!
Huff
