Outbound Dialer Agent Campaign not working
Answered Question
May 19th, 2010
ICM 7.5
CCM 7.1.3
The IVR campaign is working fine and the Dialogic Test is also workin!! but the agent based campaign is not dialing the customer, neither can i see the agent getting reserved.
Here is the log:
Allocate port: 003, owner: RESERVE_PREDICTIVE
10:32:42 Trace: (CPORT) SetState, port: 003, state: GET_AGENT
10:32:42 Trace: MRTask::ProcessNewTaskFailureEvent: Received NACK for NEW_TASK
        DialogueID=23, SendSeqNo=1, ReasonCode=Unknown routing problem
10:32:42 Trace: (PDR)   MR Reservation Failed for port: 003, state: GET_AGENT, reason: 209
10:32:42 Trace: (PDR)   End port: 003
10:32:42 Trace: (PM)
Release port: 003, state: [GET_AGENT]
10:32:42 Trace: (CPORT) SetState, port: 003, m_ReservationCallTime: 63, state: IDLE
10:32:43 Trace: (CM)    Request records from campaign manager, skill: 5012, records: 100
10:32:43 Trace: (CM)    Received customer records, count: 0, skill: 5012
10:32:44 Trace: (SGM)   Request skill stats, SG: 2, periph: 5000
10:32:44 Trace: (SGM)   Request skill stats, SG: 4, periph: 5000
10:32:44 Trace: (SGM)   Request skill stats, SG: 5, periph: 5000
10:32:44 Trace: (CM)    Request records from campaign manager, skill: 5012, records: 100
10:32:44 Trace: (CM)    Received customer records, count: 0, skill: 5012
10:32:44 Trace: (SGM)   Skill group stats received, SG: 2, agents - logged in: 5, available: 5
10:32:44 Trace: (SGM)   Skill group stats received, SG: 4, agents - logged in: 1, available: 1
10:32:44 Trace: (SGM)   Skill group stats received, SG: 5, agents - logged in: 1, available: 1
10:32:44 Trace: (SGM)   Skill group balance, SG: 5 Agents - logged in: 1, percentage: 100, available: 1, resrving: 0, cumulative ports needed: 2.50
10:32:44 Trace: (SGM)   Skill group balance, SG: 5, Port Percentage: 100.000000, Ports: 5 --> Ports Allocated: 5
10:32:44 Trace: (SGM)   Predictive reserve request, SG: 5, count: 1
10:32:44 Trace: (PDR)   Predictive dial request, SG: 5, count: 2
10:32:44 Trace: (PM)
Sandeep
Correct Answer by Abu Hadee about 6 years 11 months ago
MR PIM unable to reserve agent.
Can you check if you have label assigned for MR PIM on the Agent's Device Target?
Do you see the Routing Script gets executed?
"Router Log viewer" will be next thing to monitor when you try to run the Agent based campaign
- abu
Overall Rating: 5 (1 ratings)
Correct Answer
Abu Hadee Wed, 05/19/2010 - 03:26
  • Silver, 250 points or more
- abu
sandeep pokhriyal Wed, 05/19/2010 - 07:29
Bang on that was the issue!!!!
The call is landing on the phone now.
Thanks for the support.
