5510 5520 ASA failover license identification
May 19th, 2010
Hi everyone,
i have two ASA 5520 both with "VPN plus license" is this license OK to config the Activity/Standby failover?
best regards
mgn
Jennifer Halim Wed, 05/19/2010 - 02:11
  • Cisco Employee,
Yes, it is OK for failover.
Just have to make sure that hardware, software and any other license that you have is exactly the same between the 2 ASAs to run failover. If you have module installed, both ASAs need to have the same module too installed.
Hope that helps.
mgnmgnmgn Wed, 05/19/2010 - 19:04
Thx halijenn.i had check the hardware they are totally the same.
Will study the failover procedure and the AIM-SSM module.
thanks a lot.
LKC
mgn
