WVC210 HTTP API
May 19th, 2010
Hi to everyone
I'm trying to have WVC210 working on Synology Surveillance 4 and untill now I've been able to setup up just basic features.
In order to enable PTZ and MPEG4 audio and video stream I need full cgi api documentation ( I already have basic http commands for PTZ and http and rstp streams ).
I found cgi commands are very similar to LevelOne WCS-0020 camera but some commands needed to get PTZ presets and move to presets are differently named ( Ex. http://YourName.Linksys-Cam.com/pt/ptctrl.cgi?preset=move,1 for WVC 210 = http://<IP>/pt/ptctrl.cgi?cmd=goto_preset,<name> for WCS-0020 )
I don't have get presets command for WVC210 at all while for WCS-0020 is http://<IP>/pt/ptctrl.cgi?cmd=get_preset_list
What I want to do is to write a WVC210 compatible CGI commands API for Synology Surveillance 4 in order to fully support the camera and use Synology NAS with Linksys Cameras as Small Business surveillance system ...
I've searched anywhere but could not find any infos ...
Can someone help me ?
Thanks since now for the help I'm sure you'll give me ...
Best Regards
GP
gppiscopo Thu, 05/20/2010 - 08:15
Thanks a lot
I've downloaded and already working on it ...
Paolo
merrittuk Tue, 08/31/2010 - 04:33
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-bidi-font-family:"Times New Roman";}
Is it possible to get a copy of the CGI commands?
I have a windows mobile phone and would like to move the camera to a preloaded location with NCDelux (from Marketplace) but can’t do so until I input the CGI commands.
Many thanks
Glyn
wirtel120 Thu, 09/02/2010 - 02:19
Sorry i dont have.
"gppiscopo" have send me nothing.
Greating
GW
gppiscopo Thu, 09/02/2010 - 03:05
Just give your email ... I'll send you a copy
By
GP
streaves Mon, 05/16/2011 - 08:45
  • Cisco Employee,
Apologies for the delay in getting this published. I have forwarded the API to Abdulaziz. (Tried to send to Walter but email was returned to sender.)
We expect the API to be available for download SOON. In the meantime, you can request by email - streaves at cisco dot com.
Stephanie Reaves
Cisco Small Business
al_tamimi Thu, 05/19/2011 - 02:59
thank you very much mr.streaves , sure it help me  .
I downloaded it and  work on it but i have some problem  .
1/ No more info. on video resolution , how can change MPEG4 resolution , by use GET/POST method I try it more me be I don't know how to use.
2/ I try to change mjpeg resolution but give me error ( by use GET method and I write  a same URL command ) .
sorry for my noise but I work on wvc 210 long time ( 3 Month ) and I think it's very difficult to use .
I try to program it by use C# and i write small code to P/T/Z ( GET method ) but i need to write code to change resolution automatically by sensitive
condition .
Best Regrdes
Abdulaziz Altamimi
