IP Communicator Locale problem
Hi There !
I'm having a problem with locales in the CUCM7.1.3 (just upgraded from CM4.x).
I try to change the locale of the CIPC but it does not seem to recognize the change, and the softkeys stays in the same language.Only the right-click menu changes the language...
This is causing me a problem because some remote users are trying to download the locale, and if I configure it to use the default locale, it doesnt work... and the download restarts everytime the CIPC is opened..
Thanks for any help.
Andrei.
Andrei
Did you can solve your problem? I'm with same problem after upgrade 4.x to 7.x
It is a bug
CSCee83101
Hi !
You have to upgrade de IPCommunicator version.
7.1.3 if I'm not mistaken
Andrei.
