Aironet1131 IP Change
Answered Question
May 19th, 2010
All, I have 2 1131's that are working properly. The only issue I have is that we changed our IP scheme and the WAP's have static IP's. Consequently we cannot login to them. Once I console in, what are the steps to change the IP so we may manage the devices using the web interface? Also will this result in a disruption of service?
Thanks!!
J. Smith
Correct Answer by dancampb about 7 years 2 months ago
Once you console in just go to enable mode, then go into conifg mode and change the address of the BVI interface:
ap>en
ap# config t
ap(config)# interface BVI1
ap(config-if)# ip address x.x.x.x 255.255.255.0
Don't forget to change the default gateway too.
Overall Rating: 5 (1 ratings)
Correct Answer
dancampb Wed, 05/19/2010 - 06:38
  • Cisco Employee,
ap>en
ap# config t
smitty0375 Tue, 08/10/2010 - 11:59
Interestingly enough when I changed the BVI ip address it still didn't work. On a whim I changed the subinterface ip and I can now telnet and web into the devices. Very strange.
