Marcin Latosiewicz Wed, 05/19/2010 - 08:23
  • Cisco Employee,
I'm not going to give you exact numbers and will refrain from understanding what kind of testing you would like to do and how the test is set up.
I will say this however,
it is expected to achieve almost doubled performance while using A/A failover compared to a single unit in active by carefuly balacing traffic between units. Remember that some overhead is expected and actual results may depend on how you're testing and physical connectivity.
Marcin
