CatOS - Int details
Answered Question
May 19th, 2010
Not much familiar with CATOS
what command allows to check interface details on CATOS, module #1 48 port 10/100/1000
I m interested in getting details for int giga 1/5
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Saquib,
sh port 1/5
additional counters are reported in
sh mac 1/5
example:
sh port 2/5
* = Configured MAC Address
Port  Name               Status     Vlan       Level  Duplex Speed Type
2/5  ptocern404pp1224   connected  605        normal a-full a-1Gb 10/100/1000
Port  AuxiliaryVlan AuxVlan-Status
2/5  none          none
Port  Security Violation Shutdown-Time Age-Time Max-Addr Trap     IfIndex
2/5  disabled  shutdown             0        0        1 disabled     353
Port  Num-Addr Secure-Src-Addr     Age-Left Last-Src-Addr     Shutdown/Time-Left
2/5         0                 -          -                 -        -         -
Port  Flooding on Address Limit
2/5                    Enabled
Port  Send FlowControl  Receive FlowControl   RxPause    TxPause    Unsupported
      admin    oper     admin     oper                              opcodes
2/5  on       disagree desired   off         0          0          0
Port   Admin Channel LACP Port  Ch   Partner Oper                    Partner
       key   Mode    Priority   id   Sys ID                          Port
2/5    718  passive    128       0      0:00-00-00-00-00-00            0
Port  Status      ErrDisable Reason    Port ErrDisableTimeout  Action on Timeout
2/5  connected                     -  Enable                  No Change
Port  Align-Err  FCS-Err    Xmit-Err   Rcv-Err    UnderSize
2/5           -          0          0      32127         0
Port  Single-Col Multi-Coll Late-Coll  Excess-Col Carri-Sen Runts     Giants
2/5           0          0          0          0         0         0         0
Last-Time-Cleared
Fri May 29 2009, 12:06:27
sh mac 2/5
Port     Rcv-Unicast          Rcv-Multicast        Rcv-Broadcast
2/5               2701929405                    0              2457154
Port     Xmit-Unicast         Xmit-Multicast       Xmit-Broadcast
2/5                680508948             19331294               746433
Port     Rcv-Octet            Xmit-Octet
2/5            3993868326093         103277529193
MAC      Dely-Exced MTU-Exced  In-Discard Lrn-Discrd In-Lost    Out-Lost
2/5              0          0      32127          0          0          0
Last-Time-Cleared
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 05/19/2010 - 07:07
saquib.tandel wrote:
From memory -
"sh port 1/5"  should do it.
Jon
pciaccio Wed, 05/19/2010 - 07:08
Use the "SHOW PORT" command for port details.  The SHOW PORT COUNTERS is another good one. So for your example it will be "SHOW PORT 1/5".. Good Luck..
Correct Answer
Giuseppe Larosa Wed, 05/19/2010 - 07:19
Hello Saquib,
sh port 1/5
sh mac 1/5
example:
sh port 2/5
2/5  none          none
2/5         0                 -          -                 -        -         -
2/5                    Enabled
2/5           -          0          0      32127         0
2/5           0          0          0          0         0         0         0
Last-Time-Cleared
sh mac 2/5
2/5              0          0      32127          0          0          0
Last-Time-Cleared
Hope to help
Giuseppe
