UCCX Service Level display - Realtime
Gergely Szabo Thu, 05/20/2010 - 03:49
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
yes, either you do that using SQL queries, or by using a HTTP enabled CCX script that would use the Get Reporting Statistics step and present the information in a HTTP response.
G.
James Hawkins Tue, 03/01/2011 - 02:40
  • Blue, 1500 points or more
Hi Markus,
Did you ever figure out how to do this?
(I do not think it is possible to do using the Get Reporting Statistic step as suggested by the previous poster as Service Level is not one of the Row Identifiers within the step).
If anyone else can suggest how to do this please respond.
