EEM in 3750G
Answered Question
May 19th, 2010
Having been reading about EEM, i would like to try to use it in applet form, to track objects in IOS.
When i try to config it, i dont see the cli option event track .....
I have 12.2(50) IP services with EEM 2.40
Am i missing something?
TIA
Alan
Correct Answer by Joe Clarke about 6 years 11 months ago
While this will work, you may find the syslog solution a little better as it will not add the extra SNMP polling overhead.
Overall Rating: 5 (1 ratings)
Reza Sharifi Wed, 05/19/2010 - 10:26
  • Cisco Designated VIP,
    2017 LAN
Hi  Alan,
Do you see this command:
Switch-A(config)#event manager applet test ?
  authorization  Specify an authorization type for the applet
  class          Specify a class for the applet
  trap           Generate an SNMP trap when applet is triggered.
The above ouput is from a 3750-E
Reza
alanwright1 Wed, 05/19/2010 - 10:43
Hi Reza,
I see this at the event menu
INBOUND-STACK(config-applet)#event ?
  application        Application specific event
  cli                CLI event
  config             Configuration policy event
  counter            Counter event
  env                Environmental event
  gold               GOLD event
  interface          Interface event
  ioswdsysmon        IOS WDSysMon event
  none               Manually run policy event
  oir                OIR event
  snmp               SNMP event
  snmp-notification  SNMP Notification Event
  syslog             Syslog event
  tag                event tag identifier
  timer              Timer event
In applet conf i see this
INBOUND-STACK(config)#event manager applet test ?
alanwright1 Wed, 05/19/2010 - 11:01
Hi Reza,
I've looked at the guide, but its not clear at all how to link an event to the tracked object.
Cheers
Alan
Joe Clarke Sun, 05/30/2010 - 10:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Object tracking support for EEM does not exist in the Cat3K line.  However, you should be able to use the syslog ED to match on TRACKING-5-STATE messages.  When your tracked object changes state, do you see those syslog messages?  If so, just build an EEM applet to watch for them.  For example:
event manager applet track-down
event syslog pattern "TRACKING-5-STATE: 1 .*Up->Down"
alanwright1 Tue, 06/01/2010 - 04:12
Hi Joe, thanks for the reply, i've not yet tried that, but certainly sounds plausible
I did manage to find another way though, which i have provided for the benefit of others
event manager applet SLADOWN
event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.10 get-type exact entry-op eq entry-val "1" exit-op eq exit-val "2" poll-interval 2
action 0.5 cli command "enable"
action 1.0 cli command "conf t"
action 2.0 cli command "int g1/0/18"
action 3.0 cli command "shut"
event manager applet SLAUP
event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.10 get-type exact entry-op eq entry-val "2" exit-op eq exit-val "1" poll-interval 2
action 3.0 cli command "no shut"
Correct Answer
Joe Clarke Tue, 06/01/2010 - 08:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
alanwright1 Tue, 06/01/2010 - 08:31
Joe,
You're right, it will, but i will check the merits of both and see what one fits best. AT least i have more than one alternative
Cheers
Alan
