May 19th, 2010
Hi all.  I have 2 Cisco ASA 5520's setup in a Active/Standby failover mode.  Both units have a AIP-SSM-20 module as well.  It seems that when ever I reboot the AIP-SSM module on the primary ASA this causes the ASA's to failover.  Any suggestions as to why this is happening?  Thanks in advance.
Overall Rating: 4 (1 ratings)
jstone Wed, 08/31/2011 - 06:11
So are you saying there is no way to avoid triggering failover when an AIP is reset?
Christopher Dreier Wed, 08/31/2011 - 08:06
You can temporarily remove the Modular Policy Framework configuration that forwards traffic down to the AIP, which will disassociate the AIP's availability from the failover mechanism. However, failovers are not a bad thing fundamentally. Are you trying to avoid triggering an alarm or alert that you or your team has configured when a failover occurs? If that is the case, altering the MPF may be the best solution for you.
Thank you,
Blayne Dreier
Cisco TAC Escalation Team
**Please check out our Podcasts**
TAC Security Show:
TAC IPS Media Series:
jstone Wed, 08/31/2011 - 11:22
Thanks!  So there's a choice to be made between disabling IPS functions for a short time, and taking the performance hit of enabling failover replication for HTTP traffic, assuming long-lived HTTP sessions (Citrix comes to mind).
kulkarni.chaitanya Thu, 05/24/2012 - 06:10
What happens if the Secondary SSM module fails as well ? Will the module FAIL - OPEN, meaning permit the traffic to flow to the ASA or drop the traffic ? The logic says all the traffic will be dropped as the appliance will consider this as a hardware failure.
Please advise.
Related Content
