AnyConnect stopped working
Without any changes on ASA5520, our users couldn't use AnyConect last night.  (Cisco IPsec VPN client still works.)
After entering the correct password, it showes "Establishing VPN _Checking for updates..." AND "Unable to establish VPN".
Here is the loging output.
||||||||-- Syslog Connection Lost --
6|May 19 2010|08:18:36|725007|65.174.148.101|3226|||SSL session with client outside:65.174.148.101/3226 terminated.
6|May 19 2010|08:18:35|725002|65.174.148.101|3228|||Device completed SSL handshake with client outside:65.174.148.101/3228
6|May 19 2010|08:18:35|725003|65.174.148.101|3228|||SSL client outside:65.174.148.101/3228 request to resume previous session.
6|May 19 2010|08:18:35|725001|65.174.148.101|3228|||Starting SSL handshake with client outside:65.174.148.101/3228 for TLSv1 session.
6|May 19 2010|08:18:35|302013|65.174.148.101|3228|74.10.212.251|443|Built inbound TCP connection 468492006 for outside:65.174.148.101/3228 (65.174.148.101/3228) to NP Identity Ifc:74.10.212.251/443 (74.10.212.251/443)
6|May 19 2010|08:18:35|302014|65.174.148.101|3226|74.10.212.251|443|Teardown TCP connection 468492002 for outside:65.174.148.101/3226 to NP Identity Ifc:74.10.212.251/443 duration 0:00:00 bytes 893 TCP Reset-O
6|May 19 2010|08:18:35|725002|65.174.148.101|3227|||Device completed SSL handshake with client outside:65.174.148.101/3227
6|May 19 2010|08:18:35|725003|65.174.148.101|3227|||SSL client outside:65.174.148.101/3227 request to resume previous session.
6|May 19 2010|08:18:35|725001|65.174.148.101|3227|||Starting SSL handshake with client outside:65.174.148.101/3227 for TLSv1 session.
6|May 19 2010|08:18:35|302013|65.174.148.101|3227|74.10.212.251|443|Built inbound TCP connection 468492005 for outside:65.174.148.101/3227 (65.174.148.101/3227) to NP Identity Ifc:74.10.212.251/443 (74.10.212.251/443)
6|May 19 2010|08:18:35|716038|||||Group <SSLClientPolicy> User <chen_st> IP <65.174.148.101> Authentication: successful, Session Type: WebVPN.
6|May 19 2010|08:18:35|716001|||||Group <SSLClientPolicy> User <chen_st> IP <65.174.148.101> WebVPN session started.
6|May 19 2010|08:18:35|734001|||||DAP: User chen_st, Addr 65.174.148.101, Connection AnyConnect: The following DAP records were selected for this connection: DfltAccessPolicy
4|May 19 2010|08:18:35|113019|||||Group = Printronix, Username = chen_st, IP = 65.174.148.101, Session disconnected. Session Type: , Duration: 0h:21m:35s, Bytes xmt: 2867976, Bytes rcv: 1697322, Reason: Port Preempted
6|May 19 2010|08:18:35|716002|||||Group <SSLClientPolicy> User <chen_st> IP <65.174.148.101> WebVPN session terminated: Port Preempted.
6|May 19 2010|08:18:35|725002|65.174.148.101|3226|||Device completed SSL handshake with client outside:65.174.148.101/3226
6|May 19 2010|08:18:35|725003|65.174.148.101|3226|||SSL client outside:65.174.148.101/3226 request to resume previous session.
6|May 19 2010|08:18:35|725001|65.174.148.101|3226|||Starting SSL handshake with client outside:65.174.148.101/3226 for TLSv1 session.
6|May 19 2010|08:18:35|302013|65.174.148.101|3226|74.10.212.251|443|Built inbound TCP connection 468492002 for outside:65.174.148.101/3226 (65.174.148.101/3226) to NP Identity Ifc:74.10.212.251/443 (74.10.212.251/443)
6|May 19 2010|08:18:34|302014|65.174.148.101|3225|74.10.212.251|443|Teardown TCP connection 468491889 for outside:65.174.148.101/3225 to NP Identity Ifc:74.10.212.251/443 duration 0:00:00 bytes 1265 TCP FINs
6|May 19 2010|08:18:34|302014|65.174.148.101|3224|74.10.212.251|443|Teardown TCP connection 468491882 for outside:65.174.148.101/3224 to NP Identity Ifc:74.10.212.251/443 duration 0:00:00 bytes 1112 TCP Reset-O
6|May 19 2010|08:18:33|725002|65.174.148.101|3225|||Device completed SSL handshake with client outside:65.174.148.101/3225
6|May 19 2010|08:18:33|725003|65.174.148.101|3225|||SSL client outside:65.174.148.101/3225 request to resume previous session.
6|May 19 2010|08:18:33|725001|65.174.148.101|3225|||Starting SSL handshake with client outside:65.174.148.101/3225 for TLSv1 session.
6|May 19 2010|08:18:33|302013|65.174.148.101|3225|74.10.212.251|443|Built inbound TCP connection 468491889 for outside:65.174.148.101/3225 (65.174.148.101/3225) to NP Identity Ifc:74.10.212.251/443 (74.10.212.251/443)
6|May 19 2010|08:18:33|725002|65.174.148.101|3224|||Device completed SSL handshake with client outside:65.174.148.101/3224
6|May 19 2010|08:18:33|725001|65.174.148.101|3224|||Starting SSL handshake with client outside:65.174.148.101/3224 for TLSv1 session.
6|May 19 2010|08:18:33|302013|65.174.148.101|3224|74.10.212.251|443|Built inbound TCP connection 468491882 for outside:65.174.148.101/3224 (65.174.148.101/3224) to NP Identity Ifc:74.10.212.251/443 (74.10.212.251/443)
What is the problem?
Many thanks,
Steven
Related Content
