ASDM6.1 - FWSM question
hi!
I'm using ASDM 6.1F and i would normally add in the ACL using
the ASDM GUI. I would like to find out details of the Hits in each ACL rule. Eg, from what src/dest port was the Hits. Is there anyway that i can do it through the GUI or command line?
If i do not have a syslog svr at the moment, how do i check what has been denied access by the fiewall?
Thanks.
Jennifer Halim Thu, 05/20/2010 - 04:17
  • Cisco Employee,
Yes, you can do "show access-list " and it will show you the hit count on the access-list that is configured.
Depending on what you have configured on the ACL, whether it is source and destination specific with protocol and port specific, it will only provide hitcount on what you configured.
