IPIVR/IPCC Express BACKUP username/password change
May 19th, 2010
Hello, everyone,
Just a quick question for those who have done it before, From IPIVR 7, if I change the password/username for the back up, will that work immedidately or we have to recycle some process to make it work?
thanks
Phuong Hoai Huynh Wed, 05/19/2010 - 18:37
  • Bronze, 100 points or more
Hi apple
The change will be immediate, as the system will check if the login name/password is correct so there is no reset required.
Hoai
