How can I enable GUI in WAAS Stand By Central Manager
leninvs2502
Hi guys,
I'm testing the stand by central manager, the situation is as follows:
When the active central manager goes down I try to access the GUI in stand by central manager but it always sends me the following error
Graphical user interface is not enabled in this standby CM.
Please close  this window and go to the Primary CM.
So I think that I have to enable anything but I don't know what, can anybody help me?
Thanks in advance!
Lenin
Currently the switch to a standby CM requires manual intervention.
The benefit of the Central Manager is that it provides configuration management, device management (software upgrades, etc.), reporting, and security services from a single, central location.  Note that the security services, such as disk encryption keys, SSL certificates, etc., are available from the Standby CM (in the event that the Primary CM is unavailable) without the need to promote the Standby to Primary.
Zach
6 Replies 6
Zach Seils
Level 7
Level 7
Hi Lenin,
The activation of the Standby CM is manual.  You need to access the Standby CM and configure central-manager role primary.
Zach
Thanks Zach,
But there is something I don't understand, what is the benefit of the CM?
I thought the primary role change was automatic.
Zach
Thanks, now I have more clear on this issue
Hi Zach,
The activation of standby CM is still done manual?
Danilo,
Yes the WCM Stnadby needs to be made the primary by CLI command. The loss of the WCM does not impact the peformance of the system so it is not service impacting.
Jim
