VLAN & IP Add Scheme
Answered Question
May 19th, 2010
we have about 900 employees within 30 departments and are working to segment the LAN. Our largest department is 75 users. Does it pay to create all 24bit subnets per department or subent it out further on Catalayst 4510R-E w/SUP6 in the core. Any advice would be appreciated
Correct Answer by Ganesh Hariharan about 7 years 2 months ago
What i would suggest if this is final figure and with taking future growth in concern who can go with for max. user department which 75 with /24 subnet and for rest you can have subnetting to /25 or /26.
Hope to Help !!
Ganes.H
Remember to rate the helpful post
Overall Rating: 4.5 (2 ratings)
Jon Marshall Wed, 05/19/2010 - 13:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Assuming you are using private addressing it doesn't really matter whether you use /24s or less. Personally i would look to use /25s which would give you enough room to grow for each subnet. Key thing is not so much whether you use /24s or /25s bu that you can summarise the allocated IP subnets to anything outside the LAN.
Jon
vpollifrone Thu, 05/20/2010 - 09:03
we are using private addressing 10.10.X.X with that being said we can potentially create 30 + networks to accomodate employees and scale for future growth. I could see us doubling staff for our larger departments within the next 5 years so some /24 will be needed, other smaller departments we can use /25 or /26 and summarize all routes with a 10.0.0.0/16. thanks for your advice guys
Correct Answer
Ganesh Hariharan Wed, 05/19/2010 - 23:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to Help !!
Ganes.H
