Changing ip address of CCM 4.3 and IPCCX 6.0
May 19th, 2010
i want to know about what is the impact of changing ip address of CCM 4.3 and hostname. also IPCCX application is running on same machine. what procedure should i have to follow to change the ip address without any impact on CCM and CRS application. either we need to build the machine again after doing that ?
William Bell Wed, 05/19/2010 - 14:20
You can change IP addresses.  You will have an impact however.  The systems
will need to be restarted for the IP addresses to take affect.  There are
procedures for both products on CCO.  It is a little more involved then just
modifying the network configurations.
Note, you will not be able to change the host name without doing a complete
system rebuild.
HTH.
Bill
Please remember to rate helpful posts.
Related Content
