Static DHCP pool
May 19th, 2010
Can anyone tell me why a laptop with MAC 000c.f13f.230e wouldn't pick up the DHCP info from this pool?
ip dhcp pool bad
   hardware-address 000c.f13f.230e
John Blakley Wed, 05/19/2010 - 14:56
You may have to use client-identifier instead of hardware-address. If you're using a Windows box, it doesn't understand hardware-address. That's generally used to provide Linux boxes. Now, if you're using a Linux box, I have no idea why you didn't get that address because that should've worked.
jasonww04 Wed, 05/19/2010 - 15:07
Thanks. I just updated my config to use client-identifier. I'll let you know tomorrow if it worked.
