05-19-2010 03:04 PM
I need to change the IP address of the Outside interface remotely. I plan to SSH in to the ASA and make a change. I can't be on site to make this change since the site is out of state. Will there be any problems? The current config is
interface Ethernet0/0
nameif Outside
security-level 0
ip address 66.102.7.22 255.255.255.248
The new IP address will be 66.102.7.18 255.255.255.248. Also, is this the correct syntax?
interface Ethernet 0/0
no ip address 66.102.7.22 255.255.255.248
ip address 66.102.7.18 255.255.255.248
Thanks.
Diane
Solved! Go to Solution.
05-19-2010 03:07 PM
Diane,
If you're accessing the ASA via its public IP on its outside interface, and if you change this IP, you will lose communication with the ASA.
It's better if you can do the change from the inside.
If you definitely need to change it remotely, you can change the IP and then attempt the SSH connection on the new IP.
However if something goes wrong, you can then not access the ASA.
The syntax is correct.
Federico.
05-19-2010 03:09 PM
nameif Outside
security-level 0
ip address 66.102.7.22 255.255.255.248The new IP address will be 66.102.7.18 255.255.255.248. Also, is this the correct syntax?
Thanks.
Diane
Diane
You can't do this remotely if the only way to ssh in is via the outside interface of the ASA. If you could enter via another interface on the ASA then you can do it remotely but otherwise you will need to either visit or talk someone else through it.
Jon
05-19-2010 03:16 PM
coto.fusionet wrote:
Diane,
I'm sorry, listen to jon. As he said don't even try it.
This is because you can't change both the outside IP and the deafult gateway at the same time.
You will lose complete access to it.
Federico.
Federico
Actually the default-gateway doesn't need changing as the new address is in the same subnet so you could take the chance. I am just wary of making these sort of changes as i have done it before and sometimes it has worked and sometimes it hasn't.
Jon
05-19-2010 10:42 PM
TS, Frederico, Jon,
Maybe I'm crazy but is (or shouldnt) this be impossible?
First you do the "no ip address" command.
Since you use the IP you just removed, at this point you will already loose your connection.
Hence, your second command with the new IP will not be delivered to the ASA.
Which means you cannot access the ASA anymore from that point on, right?
Yours Sincerely,
Stan
05-20-2010 12:20 AM
Stan
You don't do the "no ip address ...", you simply type in the new ip ie. "ip address
And there is nothing worse than changing an IP of a device 100s of miles away and then not being able to reconnect. You need a fast way of getting there or an updated CV
Jon
05-19-2010 03:07 PM
Diane,
Federico.
05-19-2010 06:18 PM
Thanks Federico and Jon. I have another dumb question. If I login to Cisco VPN client and then SSH to the Outside interface, would I still be able to change the IP address? I can't be on site since the ASA is out of state. If I still can't change the IP address of the Outside interface remotely, I will need to ask the local user to connect to the ASA through the Console port. Then, I will need to give him the Enable password. Looks like I have no choice but to ask the local user for help.
Thanks.
Diane
05-19-2010 07:37 PM
You cannot do that.
The reason is because when you connect with the VPN client, you're connecting through the outside interface.
So, even if you connect with the VPN client, you will still lose connectivity if changing the IP.
As jon said, if the new IP is on the same subnet as the old IP, then you might give it a try.
However the recommendation is to do it from the inside.
Federico.
05-19-2010 03:09 PM
nameif Outside
security-level 0
Thanks.
Diane
Diane
Jon
05-19-2010 03:13 PM
Diane,
Federico.
05-19-2010 03:16 PM
Diane,
Federico.
Federico
Jon
05-19-2010 03:18 PM
Yup! agreed...
Diane... please don't do it ;p
Federico.
05-19-2010 10:42 PM
TS, Frederico, Jon,
Yours Sincerely,
Stan
05-20-2010 12:20 AM
Stan
Jon
05-28-2019 05:27 PM
You can always use
reload in mm
where mm is the minutes you like the device to reload after and make your changes and if it didn't work as intended, the device would reload from the startup config.
Just make sure to not copy the running config to the nvram before making sure everything is working fine.
