Extraneous devices in Inventory
Answered Question
May 19th, 2010
The inventory collection has picked up a number of interfaces from our core switches. However there is no way to delete these as they do not appear in the DCR or as RME Devices. How can these be cleared from the database?
Correct Answer by Joe Clarke about 7 years 2 months ago
Yes, this is possible.  Just set AAA Mode to Local, but leave the TACACS+ login module selected.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 05/19/2010 - 16:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Is LMS integrated with ACS?
marshajr Wed, 05/19/2010 - 16:48
Yes - it is currently integrated with ACS v4.2
Joe Clarke Wed, 05/19/2010 - 18:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Chances are those phantom devices are not known to ACS.  To correct this, temporarily disable ACS integration, then login to LMS and clean up DCR.  Note: this may also help your alias problem you mentioned in the other thread.  When DCR looks the way you want, re-enable ACS integration.
marshajr Wed, 05/19/2010 - 18:54
Joe - is it possible to break the integration with ACS, but still have Ciscoworks user authentication through ACS?
Correct Answer
Joe Clarke Wed, 05/19/2010 - 18:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
