05-19-2010 04:52 PM - edited 03-11-2019 10:48 AM
I'm getting an error when I try to launch ASDM via java.
The details of the error are:
Under Launch File tab-
The flash device is in use by another task.
HTTP/1.1 404 Not Found
Date: Thu, 10 Dec 2009 13:10:49 UTC
Connection: close
Content-Type: text/html
<HEAD><TITLE>404 Not Found</TITLE></HEAD><BODY BGCOLOR=#FFFFFF><H1>404 Not Found</H1>The requested URL /admin/public/asdm.jnlp was not found on this server. </BODY>
Exception tab-
MissingFieldException[ The following required field is missing from the launch file: <jnlp>]
at com.sun.javaws.jnl.XMLFormat.parse(Unknown Source)
at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source)
at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I would tend to think this is just a java issue, but I can connect to an identical 5520 with java from the same machine and it works fine. I removed and re-uploaded the bin image for ASDM to the ASA just to be sure it wasn't corrupted. Still get the same result. I'm running 8.2(2)12 on both.
05-20-2010 12:54 AM
1) What version of ASDM do you upload to the ASA? and what is the version of ASDM on the other ASA that also runs version 8.2.2(12) which is working just fine.
2) and also, can you try to access the ASA via ASDM from a different PC and see if you have the same issue.
05-20-2010 04:54 AM
Both are running 6.3.1. I just tried from another system and it works fine. Some kind of java
caching issue causing the one to fail from that machine?
05-20-2010 05:24 AM
Sounds like issue with that particular machine's Java.
Are you able to ASDM via the ASDM launcher instead of running it directly via Java?
05-20-2010 12:50 PM
Actually I don't have ASDM launcher installed because I connect to other devices running various versions of ASDM including Pix and FWSM
so I pretty much stick to the java version. I favor CLI, but ASDM definitely has some nice benefits.
