WebView Reports - How can SL_Answered be greater than Calls_Offered
Answered Question
May 19th, 2010
I am a bit confused with the WebView reports, need help.
My Skill Group report shows that calls answered within SL are greater than call offered, how could this happen? I have even checked the internal transfers if these could be part of the sl_answered, however there are no Transfer_In calls.
Also one more question, what is a difference between calls handled and calls answered?  and why dont they match even a the end of the day reports?
Answers to these questions should solve all my reporting mysteries!
Correct Answer by Gergely Szabo about 6 years 8 months ago
can you share the name/number of the WV report with us? Are you looking at a Half Hour report?
Actually, a lot of problems are caused by having to isolated mechanisms for counting calls. One is the Route_Call_Detail and the Termination_Call_Detail table combination, the other is the Peripheral Gateway/CG process counting the number of calls and filling up the Half Hour tables.
In your case, the most probable reason for the number of answered calls during a particular interval was higher than the number of offered calls is there were some calls 'overlapping' the half hour interval boundary. Pretend, there was a call incoming at 10:58 that ended 11:05. For the half hour interval 11:00-11:30 this call is not offered, but is handled.
The difference between handled and answered: well, docs quite sucks in this. It is not explained for in the schema docs for example (both contain the same definition). For your reference, the calls that are answered = picked up by the agent, the calls handled = picked up by the agent AND completed.
G.
Overall Rating: 5 (1 ratings)
Correct Answer
Gergely Szabo Thu, 05/20/2010 - 03:26
G.
girish_sutar Thu, 05/20/2010 - 09:26
Thanks a ton for answering this, its like a mystery resolved for me.
I have attached sample report for two days for your reference. I have highlighted the intervals where the calls answered are greater than offered.
Do let me know if there are any specific issues with this report.
Also i still fail to understand why would  the calls handled and calls answered not match in the end of the day report.
Apologies for asking this again.
I understand while the contact centre is operational there could be a difference because few agents are still on call, however when the IVR is closed and I spool the report second day then I assume the calls answered and handled should match.
Girish
girish_sutar Thu, 05/20/2010 - 18:32
Thanks Geoff for your reply.
I am new to CISCO and i got to learn that the Skill Group report is used to measure the Service Levels.
However it seems i am wrong and I should be referring to Call Types report.
I was going thru the templates and found calltyp21 & 22 report which shows the SL. Please let me know which report should be used to measue SL, Abandon, Answered, etc?
Also me being new to CISCO, what are the readings you suggest so that i can understand CISCO reports better.
Apologies for throwing so many questions.
Thanks for your support & Thanks to the CISCO support community - A Knowledge Bank!
Yep, calltyp21 and calltyp22 are good ones. But the accuracy of these reports depend on how well your scripts are "instrumented" with call types. If you have just 1 call type attached to a dialed number which is then scheduled against a script, this may not be sufficient.
If your script considers holidays and opening hours and carves off these calls, you will get inaccurate data if you rely on the 1 call type. What Cisco recommend, and what most integrators do, is add a number of "Call Type" nodes that change the call type as the call moves through the script.
This enables you to get peg counts on entry, holidays, closed, emergency etc. Then there is typically a final call type - I call it a "queuing call type" - because it is set just before the Queue to Skill Group node (or a series of these if you have more complex queuing). I have a naming convention that this call type ends with "_Q" so it's easy to find in WebView.
There will be no more call types after this one. This call type gives accurate service levels - no calls will "overflow out" to another call type. Check the Cisco Scripting Guide for advice on this.
Geoff
girish_sutar Fri, 05/21/2010 - 17:58
Thanks Geoff, this really gives me an overview on how the reports are to be studied and makes me more clear on the call routing.
One observation i have found in my Skill Group reports is the contact centre starts taking calls at 9:00am. Even at this interval the calls answered are more than calls offered? Now this is really a surprise for me.
I will now go ahead into further more analysis and understand real time how things are happening at my contact centre. However could you please let me know if i am following the right direction.
Our Contact Centre works between 9:00am to 9:00pm, Sunday being off. Post dialling the toll free number the customer goes thru various IVR options and then if he wishes the call is transferred to the CSE. Under this scenario what reports do i consider to measure my Service Levels? As you have suggested below i find the queuing call type node and then analyse my SLs.
Once again apologies for asking so many questions but this forum has really helped me answer my queries to satisfaction.
It's not a matter of "find the queuing call type node" - I made that name up. It's a matter of adding a call type just before your Queue to Skill Group node and using the call type reports on that call type for your service levels.
Geoff
girish_sutar Sun, 05/23/2010 - 08:22
Thanks Geoff for your help.
One last query from my previous question, if i am not troubling you a lot.
How do i address the above scenario where the calls answered are more than offered in the opening interval itself. I can understand during the day, however this is a mystery for me.
What could be the probable cause for this?
Girish
Diwakar.D_2 Mon, 05/24/2010 - 02:50
Can you please share the report number or the description of the reports you are refering to?
girish_sutar Mon, 05/24/2010 - 08:08
Hi Diwakar,
I am referring to the Skill Group Report ( IPCC Peripheral Skill Group Consolidated Half Hour Report perskg35).
Girish
Gergely Szabo Mon, 05/24/2010 - 09:05
in the same script, how many skill groups may be a particular call routed to?
I found this in the schema docs that may be interesting:
ServiceLevelCallsToHalf
Calls may abandon while in the Skill Group queue,or they may abandon after they have been routedto a Skill Group.
Calls that abandon after they are routed to a SkillGroup are identified by TCD records withabandoned call disposition flag.
If the call is queued and abandons before it is routed to any Skill Groups (within the ServiceLevel threshold), the Router will increment this value forALL the Skill Groups this call was queued for.
If the call abandons after it was routed to a SkillGroup, that Skill Group will haveServiceLevelCallsAband incremented.
So if a call is abandoned while being queued for multiple skill groups, this may increment the above value for all skill groups.
So if you are watching one skill group, there may be calls involved for other skill groups.
G.
girish_sutar Mon, 05/24/2010 - 18:33
Thanks netbakter for your response.
Basically we have two skill groups as per the customers language preferences. So even if i club both these reports to understand the offered and sl_answered there is a variance. I have attached the report for your reference.
Need your input on how do I analyse the call flow and service level-
In our scenario, the contact centre operates from 9:00am to 9:00pm. There is an IVR with some self help options and if the customer wants to speak to CSE, then he chooses relevant information.
So to get a correct picture on SL, does it mean i start tracking the calls right from the call landing at IVR, getting filtered thru various IVR options and then analysing how many calls are being actually transferred to CSE? Currently i am studying only the Skill Group report where the calls are answered by CSEs.
Girish
Call type reports are the only way here - that's what they are designed to do in an IPCC system. That's what I have been saying.
Create a call type right before your first queue to skill group node. Make sure this call type can never be changed.
What is "service level"? Is it something to do with agents, or skill groups? No. It is a measure of the customer experience. What percentage of calls were answered within a  certain number of seconds.
If you have a complex routing script with calls overflowing into more and more skills as queue time passes, how could you figure out the SL from multiple skill groups?
Create a call type and measure it.
Geoff
Gergely Szabo Tue, 05/25/2010 - 00:12
I cannot agree more with Geoff. It depends on what you want to achieve and from what point of view. If you are interested in the Service Level, it is the customer's point of view: for instance, you make up a formula like "80 percent of calls that passed the IVR should be answered by an agent within 20 seconds". In this case, you are actually working with two call types: one is the initial one that actually serves as a link between the dialed number and the routing script, the second is actually kind of resetting the call related timers in order to see what's happening beyond a certain point - in this case this point is a place behind an IVR option: the CallType node with a different call type.
I took a look a those Excel sheets you attached, but I cannot see anything suspicious, could you please just tell me which row numbers you are referring to? Thanks.
G.
girish_sutar Tue, 05/25/2010 - 02:00
Hi netbakter
I have attached the skill group report for your reference and highlighted the rows under column E where i find an issue. These cells highlighted are the opening intervals for our contact centre, where the SL_Answered(refer column AO) are more than CallsOffered.
As mentioned earlier we have two skill groups where the calls are answered basis customers language preferences.\
Hope this helps.
Girish
Gergely Szabo Tue, 05/25/2010 - 02:32
can you please also attach the screenshot of the ICM routing script?
Of course, I will not misuse it, disclose it to the US Government, etc etc.
G.
girish_sutar Tue, 05/25/2010 - 02:46
Being an operations guy I have limited or no access to the scripting part. However will try to get these from my tech guys.
In meanwhile, do you feel there are any patterns in the data which seem to be wrong?
Girish
Gergely Szabo Tue, 05/25/2010 - 03:27
Hi, what I think is the pattern I described above in one of my previous posts should be applied here, ie. calls abandoned in the queue for several skill groups within the service level are incrementing value for one particular skill group. This is why I would like to see the script.
Also, do you have access to the Termination_Call_Detail and the Route_Call_Detail tables?
G.
neeraj.suriyal@... Wed, 04/04/2012 - 03:21
i have same concern " Callanswered is greater than Calls offered", and in the previous interval there is no calls offered/answered/handled so no point of calls came in first interval and answered in next interval.
i am refering "perskg36: IPCC Peripheral Skill Group Consolidated  Daily"
Gergely Szabo Wed, 04/04/2012 - 04:05
can you please give us more details. What columns are trying to compare. What is your UCCE version. Is this a customised report.
Thanks.
G.
neeraj.suriyal@... Wed, 04/04/2012 - 04:17
HI Gergely,
we are using UCCE 8.0.X version. this is not customized reports we are pulling data from webview (perskg36: IPCC Peripheral Skill Group Consolidated  Daily)
below are the field which i am campairing.
Intervalskill_group_enterprisenameCallsOfferedcallsanswered
3/29/2012   0:00Skill_100
3/29/2012   0:30Skill_100
3/29/2012   1:00Skill_100
3/29/2012   1:30Skill_100
3/29/2012   2:00Skill_100
3/29/2012   2:30Skill_100
3/29/2012   3:00Skill_100
3/29/2012   3:30Skill_100
3/29/2012   4:00Skill_145
Gergely Szabo Wed, 04/04/2012 - 04:50
thanks.
I did some analysis and now I can see you kind of misinterpreted some columns.
I guess what you don't like in this report is how come the value of the 'Total' column is lower than the value of the 'Ans' column.
Actually, 'Total' in this case is 'Completed Tasks Total' and 'Ans' is 'Service Level Ans'.
Service Level Ans
WV definition:
The number of calls that are answered within the skill group service level threshold in the half hour interval.
Derived from: Skill_Group_Half_Hour.ServiceLevelCallsToHalf
Schema definition:
The value of this field represents the number of calls answered within
the service level.
Completed Tasks: Total
WV definition:
The total number of tasks completed by this Skill Group in the half hour interval.
Derived from: (Skill_Group_Half_Hour.CallsHandledToHalf +
               Skill_Group_Half_Hour.RouterCallsAbandQToHalf +
               Skill_Group_Half_Hour.AbandonRingCallsToHalf +
               Skill_Group_Half_Hour.RedirectNoAnswertoHalf)
Going a bit further, you can see, all these 4 calls were handled, so
Schema definition:
The number of inbound ACD calls answered and wrap-up completed
by agents associated with this skill group during the half-hour interval.
This field is applicable for Unified ICME andd Unified CCE.
A handled call is:
• An incoming ACD call that was answered by an agent, and then
completed.
• A non-voice task that the agent started working on then completed.
A handled call/task is completed when the agent associated with the
call/task finishes the wrap-up work associated with the call/task.
I've got a strong feeling you think the 'Total' is actually 'CallsOffered', which is not in this report.
G.
neeraj.suriyal@... Wed, 04/04/2012 - 04:56
Thanks for information. But if you see there is no calls offered before the highlighted interval then why calls answered value is greater than calls offered.
Neeraj Suriyal
Phone:+1-646-367-8324
Extn:6790
neeraj.suriyal@... Wed, 04/04/2012 - 05:15
In the webview report. After exporting the report and open it in excel.
Below is the snap shot of the report(other field are hidden)
Interval
SkillGroupSkillID
LoggedOnTime
CallsOffered
callsanswered
3/29/2012 0:00
IB_Apple_MAC_IYG_GGN_Tier1_sg
20497
20497
20497
20497
20497
20497
20497
20497
1663
20497
4519
Neeraj Suriyal
Extn:6790
Gergely Szabo Wed, 04/04/2012 - 05:34
no, in this case a column named 'callsoffered' does not equal to the database table column CallsOffered.
I guess a Cisco guy wanted to save some work so he named this column callsoffered.
I opened this report in InfoMaker and I see this callsoffered is actually:
CallsOffered = SUM(ISNULL(SGHH.CallsHandledToHalf, 0)) + SUM(ISNULL(SGHH.RouterCallsAbandQToHalf, 0)) + SUM(ISNULL(SGHH.AbandonRingCallsToHalf, 0))+ SUM(ISNULL(SGHH.RedirectNoAnsCallsToHalf, 0)),
And this is actually the 'Completed Tasks: Total'
So the exported report column name is misleading. It should be 'CompletedTasksTotal' or similar, but not 'CallsOffered'.
I hope it's clear now.
One more thing about exporting: do not use the Excel format. Use HTML and then import the HTML file into Excel.
G.
