Cisco ACS config file
Answered Question
May 19th, 2010
Hi all,
I have a cisco ACS V.4.0 server and want to get the config file. How can I get the CLI command prompt ? Or, Any where I can get the config file ?
Leung Che Man
Correct Answer by Jatin Katyal about 6 years 8 months ago
Unfortunately, that is not supported. You've to connect to ACS via hyperterminal using console cable.
Regds,
JK
Do rate helpul posts-
Overall Rating: 5 (2 ratings)
Jatin Katyal Wed, 05/19/2010 - 18:53
You can always take ACS backup from the GUI by going to System Configuration >>  Click ACS Backup >> enter the FTP information >> Backup now.
Performing a Manual ACS Backup
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/sba.html#wp222516
Once you connected to ACS via CLI the default username and password if not changed would be
user= Administrator
Pass= setup
Establishing a Serial Console Connection
http://cisco.biz/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/installation/guide/appliance/instalap.html#wpxref17544
Backing Up ACS Data From the Serial Console
http://cisco.biz/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/installation/guide/appliance/admap.html#wp1057928
Regds,
JK
Do rate helpful posts-
cm6043 Wed, 05/19/2010 - 20:25
Hi jkatyal,
Thanks for your information. Could I get CLI prompt remotely ?
Leung che Man
Correct Answer
Jatin Katyal Thu, 05/20/2010 - 02:50
Regds,
JK
