Input error
support.golan
hello
i am useing cisco 1841 router connected to my server IBM X3550 both interfaces set to 100 MB/Full duplex,even thats i see an input error.
what should i do ?
i try to change it to speed & duplex to auto
my server connected to router directly(no swtich or other accessories betwean them)
thanks
golan
8 Replies 8
Giuseppe Larosa
Hello Golan,
what type of errors are you seeing?
post a sh interface fas0/x
Hope to help
Giuseppe
router#show interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0024.14fc.0204 (bia 0024.14fc.0204)
  Description: router-server(london)
  Internet address is 10.2.1.2/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:07:28, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w3d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 503000 bits/sec, 724 packets/sec
  5 minute output rate 2000 bits/sec, 4 packets/sec
     268678717 packets input, 2538389555 bytes
     Received 1246 broadcasts, 0 runts, 0 giants, 0 throttles
     2083 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     1752741 packets output, 141470490 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
router#i
Hello Golan,
2083 errored packets over 268678717 is not a real issue
Hope to help
Giuseppe
thanks
but for me its real issue,can i change it to ZERO ?
the reason is 2083 becuase there is no traffice,but if the traffic growth as the same the input error are growth toghter.
thanks golan
Hello Golan,
I understand
what hits my attention is that the input error should appear under one category like ignored or CRC error or runt.
in your show we don't see this, the errors do not belong to a known category.
This doesn't help in finding a solution
I would focus on flow control: the server may be moving packets too fast for the router
Hope to help
Giuseppe
thanks
but how can check it?
I would issue the clear counters command and then monitor the interfaces to see if the input errors increment again.
In networking there is no such thing as "for me".
Things are what they are, not what you want them to be.
As Giusepped correctly stated, the error ratio is so small to be negligible, and has to be ignored. I have rated his post.
