SR520 IPS
May 20th, 2010
I have some troubles with the initial setup of IPS on a SR520 router
The router has IOS 12.4(24)T3-ADV-IP-SERV-Crypto
I'm using CCA 2.2.4
When configuring IPS with CCA then I'm first asked to get the public key. This part is working.
Next is to install SDF.
As there is the the known issue with 128MB size, I'm trying to install sigv5-SDM-S384.zip file.
When trying to apply then I get first the message Operation in Progress for about 30 sec.
Then the process stops with following errormessage:
Failed to load IPS Signature Package. To continue configuring IPS:
1. Close the IPS window
2. Click the Refresh iconin the CCA toolbr to perorm a global refresh.
3. Re-open the IPS window an continue configuring IPS.
Of course I tried this...
Can anybody help ? Or how to install the sdf manually ?
Karl
