851W Wireless configuration
May 20th, 2010
I've configured a 851W in order to have 1 single broadcast domain: wired and wireless client should be in the same vlan.
Client connecting to ethernet ports work fine, client connecting to Wireless are able to associate with the AP however are unable to communicate with host in the LAN.
I am used with Aironet, setting up the BVI interface, and the ethernet subinterfaces; in this circumstance, however, i have configured only the radio part, assuming there is only 1 vlan and the interface vlan would act as gateway for the hosts.
Does anybody can tell me where is the problem?
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 1800 membership-termination capability-change
encryption vlan 1 mode ciphers tkip
ssid Test
    vlan 1
    authentication open
    authentication key-management wpa
    wpa-psk ascii 7 ***********
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
interface Dot11Radio0.1
description ** WLAN **
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description ** LAN **
ip address
ip nat inside
ip virtual-reassembly
alfredos Tue, 05/25/2010 - 11:32
I'm not an expert in BVI configs (which I dislike) but I'd try to configure bridge-group 1 under the vlan1 interface.
