7604 Router boot trouble
May 20th, 2010
on my 7604 router with 720sup I have next trouble. After router reboot it can not be loaded.
By DATA-port I recieved following:
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:c7600s72033-advipservicesk9-mz.122-33.SRB2.bin"
Loading image, please wait ...
Invalid device specified
Booting from default device
Initializing ATA monitor library...
string is bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF8.bin
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################### [OK]
%SYSTEM-1-INITFAIL: Network boot is not supported.
and repeat this without end.
Press break key and boot from rommon only helps:
rommon 1 >boot
There is string from config relating to boot:
boot system sup-bootflash:c7600s72033-advipservicesk9-mz.122-33.SRB2.bin
Somw show-commands result:
Ch73-201-Cat7604#sh boot
BOOT variable =
sup-bootflash:c7600s72033-advipservicesk9-mz.122-33.SRB2.bin,12;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not present.
Ch73-201-Cat7604#sh sup-bootdisk:
-#- --length-- -----date/time------ path
1     81798660 Jun 01 2007 17:53:36 s72033-ipservicesk9_wan-mz.122-18.SXF8.bin
2     33554432 Nov 18 2007 22:45:12 sea_log.dat
3    111003652 Nov 18 2007 10:34:08 c7600s72033-advipservicesk9-mz.122-33.SRB2.bin
285655040 bytes available (226369536 bytes used)
Why can't load image c7600s72033-advipservicesk9-mz.122-33.SRB2.bin? How can I correct this?
Related Content
