7206VXR PDSN-high CPU rate.
May 20th, 2010
Dear All
Thank you for read my question. and my english express is a not perfect and not good ^^ please understand and help me!
Current, we have been changed NPE400 to NPE-G1 because we got too much CPU rate.
We are using this modle for PDSN and when we changed to NPE-G1 the CPU is 60% but our customer want to less than 60%.
Do you have any solution or how can I check more detail traffic rate? I mean if the CPU get more higher than 60%, i have to use some command.
But I just knew a few commande for check it.
I only knew show process cpu, show process cpu | inculde 0.00, show 7200.....
Could you tell me the other command for check ?
One more thing, we got Five 7206VXR for use PDSN but all PDSN has a high CPU rate. it's not only busy time.
It's a normal they record 60% or over 60%.
Our cutomer serving CDMA 1x Data service to user. and this is our running IOS version , c7200-c6is-mz.123-14.YX4.bin.
So, which part do I have to check for reduce CPU rate?
Thanks & Regards,
