Certificate error in IE for WLAN web-auth
May 20th, 2010
Hello guys.
i just set up an enterprise wireless network with guest access using 2 WiSMs (code as internal controllers and 2 5508 WLCs (code as guest anchor controllers. i am using web-auth for the guest wlans and everything works just fine.
we purchased a Verisign certificate and downloaded it to the guest anhor controllers for the web-auth login page and for some reason, we get an invalid certificate error prompt from Internet Explorer while Firefox comes up just fine from the same client.
please i will appreciate suggestions on how to crack this.
thanx in advance for the help
dancampb Thu, 05/20/2010 - 09:09
The error that pops up in IE should say way it failed.  What is the reason listed in the error?
sayrmatics Thu, 05/20/2010 - 09:32
the error we get in IE is the standard security warning saying "there is a problem with this website's security certificate. the security certificate presented by this website was not issued by a trusted certificate authority" as mentioned earlier, the cert was issued by Verisign
sayrmatics Fri, 06/18/2010 - 08:33
i got a solution to this the moment i discovered that verisign stopped issuing  unchained certificates years ago. here's how i went  about it:
1. i downloaded openssl, generated the csr and submitted  to verisign.
2. i copied the digital certificate from verisign in  x509 format.
3. i downloaded the root CA certs and intermediate  CA cert files from verisign for the class of certificate we ordered (secure  server g2)
4. i combined the files as per cisco instruction and  converted to .pem using openssl.
5. i downloaded the cert file to  the wlc via cli and reset the controllers.
hope someone finds this useful
Trending Topics - Security & Network
