network-boot over different ip-segments with old hp-workstation
May 20th, 2010
hi,
we have in our factory old hp-workstations, which boot from the network and catch their boot-image from an server. it works fine, when client and server are in the same ip-segment. when we set the client in a differnt ip-segment, nothing works. i analyse the boot-process with wireshark (find the file attached). the client send bootrequests over the rmp (hp remote maintenance protocol) to the server.
my question: is it possible to set a config like "ip-helper" on the interface, behind which the client is, so that all the boot-requests will be send to the correct server?
here is a short layerdescription of the boot-request (see details in the capture-file) --> in the capture-file you have to set this filter:
eth.addr == 08:00:09:F2:2a:61
Frame 321 (60 bytes on wire, 60 bytes captured)
IEEE 802.3 Ethernet
Logical-Link Control
HP Extended Local-Link Control
HP Remote Maintenance Protocol
thanks in advance for your help!
thomas
thomas.luxl Thu, 05/20/2010 - 07:33
little addition: in the capture-file you have to set this filter:
thomas
