Nexus 5010 management port - single or dual?
May 20th, 2010
Hi, I have a couple of 5010 Nexus switches. There are two physical ports on the front next to the L1 and L2 ports, but in the console I can only see mgmt0 and the device on the other end of the cables doesn't see a link on the second port. Do these devices actually support both management ports? The documentation is fairly sparse on this area.
Lucien Avramov Thu, 05/20/2010 - 07:58
  • Red, 2250 points or more
Only mgmt0 port (1 port) is supported for management on the Nexus 5000.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
